Fabrication CADMEP Database to Revit Database
How can I use my existing Autodesk Fabrication CADMEP database to my Autodesk Revit 2016.
Can anyone help me in my problem.Or any video that can help me setup.
You can email me at
juliusnatividadmendoza@gmail.com
julius.mendoza@forsspac.com
Thank you.
TBodor1
Have you gone into the Fabrication settings and seen if the appropriate services are associated? Did you try the help files?
I try to set the GUID in the Autodesk Fabrication CADMEP buti still in the selection of Revit fabrication configuration the database was not shown, but only the dafault fabrication configuration shows.
See image below;
The GUID is only part of the issue.
Per your Screen Caps, you're using 2015 CADmep and 2016 Revit.
Which configurations are available are stored on a "per version" basis.
So 2015 looks in the 2015 section of the registry to see which databases are available. 2016 looks in the 2016 section of the registry.
Easiest way to fix this if you're not comfortable editing the registry is to launch CADmep 2016 and add/browse to your configuration. That'll att it to the proper section of the registry and Revit 2016 will then see it.
