Fabrication CADmep 2018 Profiles
I recently created a new profile. After creating the new profile I used the "mapprofile" command. now all I see is the global and the new profile I created. in my database all of my previous profiles and information is there but they wont show up using "mapprofiles". Is this a simple path issue?
pinaki.rajak
Dear Friend,
After placing the command "mapprofiles" you may chooses new profile "green button" and created profile with"Copy nothing / Create Blank profile" option active. There are also two other profile options as well, please check and confirm yourself whether you followed proper options as per your requirement.
Hope this will help you to understand the issue.
Please press kudo and " Accept as Solution" if you benefited.
