Fabrication CADmep 2017 Spooling while utilizing Profiles reverts to Global
It appears that the latest Fabrication update may have corrupted something involving Spooling while utilizing profiles.
On multiple machines, users are experiencing an issue where after "Batch Spool" a selection the both project files revert to the "Global Profile" and changes the service the spool is associated with in both the main file & the Spooled Piece.
Could a setting have bee changed in the Spool.ini file?
If not, this is a major issue that Autodesk needs to resolve ASAP.
I have the same issue.
Autodesk: My drawings are being globalized by the new update. In addition I have no way to roll back the update. I thought it was in my spool.ini file as well; lot's of lost time on this.
Any updates on this issue which is quite old now?
Update: Received an email this morning from Autodesk; they are now aware of the problem and an update will be posted shortly. I will reply here once I get confirmation the fix has been posted.
