Fabrication API ContentManager.SaveItemAs doesn't seem to work from CAMduct 2023
- Mute
- Permalink
- Report
Dear forum master or anyone else,
This is regarding a small add-in I was trying to do in CAMduct 2023 using Fabrication API. Please see the attached MAJ file in the zip. Open the MAJ file in CAMduct and run the C# code snippet below:
var item1 = Job.Items[0];
var path1 = Environment.GetFolderPath(Environment.SpecialFolder.UserProfile);
//path1 += "\\Item1.ITM";
var saveResult = ContentManager.SaveItemAs(item1, path1, "ItemName1", true);
I tried to make path1 as a pure path, or to make it as a full path file name. None of them seem to work. The return message is "Invalid parameters". I also tried to make "ItemName1" the actual name of the item. No luck so far. Can you indicate what I did wrong?
Thank you!
Jeff Yao
