Fabrication API Bugs Regarding ItemOptions
If I take an ItemMinMaxNumericOption and try to set it to it's lowest value, I get the result "The value is outside the option's lowest and highest bounds". Except I'm literally grabbing the lowest value saved into that option and writing it back in.
Similarly, I'm looking at a square elbow (CID 3) and the item option for "Seam Number for Throat" [7] is coming out of the wash as an ItemOption, subclass of ItemOptionBase.
ItemOption property named "Value" is read only. I cannot seem to write to it. However, the other subclasses of ItemOptionBase all have either a read/write Value or a method to access its manipulation such as ChangeValue().
Apologies if I'm mistaken on any of these
Replies (0)
