Fabrication 2017 Section Data not DIsplayed Properly in Navisworks 2017
In AutoCAD, the "FORCETOOLTIP" command will allow you to hover over Fabrication items and display certain intelligence (Item#, Item Description, Item Size, Button Code, Item Elevation, Section Data Designation, Service, Item Size, and Item CID#). I have all my settings in AutoCAD environment & Navisworks environment setup correctly for this to displaying properly. I've selected the same settings I've always used in the past to have all this information displayed in a certain format but, the Levels are not translating over the Section Data elevation from AutoCAD to Navisworks. The Fabrication Database format is Architectural 1'-3 1/2" with BOP elevation designated. The AutoCAD Units are also in Architectural / Inches format. The Fabrication Section Data has also been formatted for the project Deck elevations. Everything displays correctly in AutoCAD environment as shown in Screen Shot-1. However, despite utilizing Navisworks format settings used in the past, the  elevation display is not only in Decimal Inches, but also doesn't reflect Fabrication Section Data as shown in Screen Shot-2. Any Suggestions?
Replies (0)
