Fabrication 2015 SP2 is not saving Job Info
MOatman
MOatman
I fill out job info and then save and close the drawing.  When I re-open the drawing and check the job info it is all blank.
cam-nav
Are you using the "Custom" JOBINFO form?
MOatman
No just the standard one from the jobinfo command.
jmerch
We've had this issue in 2014 when setting up new jobs. We just insert a piece of content temporarily until the actual content gets modeled in order to keep the information filled out.
MOatman
Job info is being lost even with fabrication objects in the drawing.
It will save it as long as the drawing session stays open but when you close cad and re-open drawing it is gone.
jmerch
Ah, that's odd. Can't help you there.
