Fabrication 2015 CAM/EST Issue
nbaughman
nbaughman
Whenever I do database management, I like to use keyboard macros to help automate the process. In 2014 CAM/EST you were able to select an item in a list and hit the "menu key" on your keyboard, which would function as a right click.... see below....
In 2015, with any service pack installed, it now brings up this menu... see below
In 2015 CAM/EST (possibly CADmep) it only gives me the "new" option. This is going to slow me down dramatically when doing costing updates within 2015. I have tried on other PCs with the same result.
Please fix!!!
Best Regards,
Nick
cadman_ics
Are you still having this issue?
I am able to use the menu key as you describe in both 2015 SP4 & 2016.
nbaughman
Yep, it has been fixed in 2015 SP4 & 2016. They also fixed the functionality of the tab button within the sub-menu.
