FABmep to RFA
FABmep to RFA
Is there any way of converting or exporting the 3D components from FABMEP to REVIT RFA?
If this is not possible is there a way of exporting/ converting any of the file types on Building3Dcontent.com to RFA
jade.l
As I know, currently there is no method to convert .itm file to .rfa file.
If you want to use .itm file in Revit, you could prepare a config and load it in Revit after 2016 version.
http://help.autodesk.com/view/RVT/2016/ENU/?guid=GUID-692C4E68-6A9D-4628-8E73-0C327E5677D4
Hope it helps
jade.l
nathan.chapman
One thing to add to this is that not all ITM patterns are supported in Revit currently.  So some items that should up in the Fabrication product will not show up in Revit.  If you search the internet you will find a list of supported Patterns.
Nate
Nathan Chapman
Production Manager at General Heating and Air Conditioning
Revit Architecture Certified Professional
Revit MEP Mechanical Certified Professional
Revit MEP Electrical Certified Professional
DynaFabrication Package Author
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDOS button.
