Fab table import error
dcapestany
dcapestany
So I export my fab tables in ESTmep 2015 as a .mtt file then when I go to import them as an .mtt in ESTmep2016 the only way to get them in is as a install table.  This is not going to work.
dcapestany
Just noticed that same problem occurs when going from version 2016 to version 2016.  There is no way to import an mtt file as a fab table instead of a instalation labor table.
cadman_ics
I can confirm that I have your same issue with trying to import a *.mtt file containing fabrication times; will only import as installation times.
In 2016 just use the defualt *.iox file format; it will allow fabrication times to be exported & imported.
