Fab MEP 2019 - Duct taps notworking correctly
FMMCorp
FMMCorp
I am trying to make an 18"x6" tap off of a 10"x10" main.
When using design line, it keeps adding taps in a weird way (see photo 1)
I am new to the software, perhaps I am doing something wrong...
Oddly this was not an issue earlier (see photo 2 ) but I cannot get this to work.
Any suggestions/help would be appreciated.
Thank You.
david.dykes
Hi Steve
I have sent you an e-mail requesting the Service you are using, I believe it will be down to the Button Mapping you have set up.
Send me the files and I will look into it.
FMMCorp
Hi David,
Thanks for the response.
File attached.
I'm a beginner with software so it may just be my settings.
Appreciate the time & help.
-Steve
david.dykes
I need the Service that you use, I can't tell the Button Mappings from a drawing.  Use EXPORTSYS to select the service you used and export the file (.IEZ)
FMMCorp
I apologize, I thought I attached it. See attached.
david.dykes
Doesn't look like the forum allows the attachment of iez files as there wasn't anything attached to your last post, can you reply to the e-mail I sent with the .iez attached.
david.dykes
Hi Steve,
I think I've cracked it, please watch the Screencast.
https://autode.sk/2PM5EoL
