Fab CADmep IFC export Distorted when inserting to Revit 2016
I have designed a model in Fab CADMEP , this needs to be inserted to a Revit 2015 Model..when i export the model from CADmep as an IFC and link the IFC to Revit, the model becomes distorted, Have you any idea what could be the cause of this?
Sean
nathan.chapman
Do you happen to have a screen shot of the distortion?  How far away from the Revit origin is the IFC coming in?  Large distances from origin in Revit will cause weird graphics issue.
Nathan Chapman
Production Manager at General Heating and Air Conditioning
Revit Architecture Certified Professional
Revit MEP Mechanical Certified Professional
Revit MEP Electrical Certified Professional
DynaFabrication Package Author
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDOS button.
Yeah the IFC is coming in miles away from the Revit origin, see image of distortion below.
tech3design
I have the same issue. they don't show up in my revit file. MAP proxies are evil.... They can not be used or viewed in Revit. Why?
I have had the AUTOCAD Fabrication enabler installed.
I can not create an IFC file from these two files.
Where are the experts that can tell me why,
Thank you,
