EXPORT DATABASE/TAKEOFF/CAD SETTINGS FOR UPGRADE
clomedico
clomedico
Is there a way to export your database/ takeoff / cad setting out of 2018  and import it into 2019.  I exported services and DBEXPORT for connections and other items but i don't see an option for cad settings.  Also would be nice if cad settings were drawing specific as i use different settings for piping vs HVAC drawings.  I have to change them each time i open the drawing or it just uses what the current setting is.
davidronson
You don't need to upgrade like that. Just map the 2019 product to your company database. All the content is forward and backwards compatible...minus any features not available in previous releases.
______________________________________________
Don't forget to "Accept As Solution" and "Give Kudos" when an acceptable solution has been given.
|| LinkedIn || LinkedIn Fabrication Group ||
David is correct. You shouldn't upgrade your database release to release.
That being said, CADINFO.MAP is the file that contains the "CAD Settings". You'll find it in the same folder as the MAP.INI file which is where your fabrication database configuration points to. The MAP.INI then points to the rest of the database settings.
Because MAP.INI is what shows up in the configuration selection dialog, and because it also finds the rest of your database, you can "Seperate" some of the settings by having 2 different folders for the MAP.INI file and the other files in that folder. Those MAP.INI files should point to the same location for the rest of the database. But because there's 2 MAP.INI files (or more), there's also then 2 CADINFO.MAP files which will allow you to set some things different.
This would allow you for instance, to set fractional inches for length on sheetmetal and use the diameter symbol for round duct sizes but also use ft-inch format for pipe lengths and no diameter symbol for size.
This is also the easiest way to spin up a "soft metric" configuration where everything is drawn imperial but annotated in metric.
david.dykes
Hi Christopher,
While the other Solutions will work I would recommend you use the Fabrication Migration Tool to import your 2018 configuration into 2019.  This will keep your personal settings intact.
I have made a short Screencast showing the process:
https://autode.sk/2IiPUW5
