Error 4 unable to open file
Hope someone can help
I have had problems with the item library disappearing, but i've managed to get them back but have now got an Object I/O "C:/user/Dave/Appdata/Local/Autodesk/fabrication2018/Cadmep/cadtakeoff.map" Error 4 - unable to open file
I can retry or cancel
If i retry the error stays up, if i cancel the item is added.
This is occurring if i modify an item or amend an existing item.
The duct is modified but keep getting the error panel is very annoying.
can anyone help please?
Cheers
jpnoronha
Hi
There is an Autodesk page about this issue here https://knowledge.autodesk.com/support/fabrication-products/troubleshooting/caas/sfdcarticles/sfdcar...
Causes:
CADTAKEOFF.MAP file is locked or corrupted.
Hope it helps
Regards
