Elevation Datum on Ctext
LFM.VDC
LFM.VDC
I Have a ctext report that reports out elelation for piping however, the ctext does take into account the elelvationdatum for the section that the pipe is on. is there something I am missing when making the Ctext report?
Luciano
For Elevations, use a block with an attribute.  You can then add the name of your block under Service Types (Level Block).  See attached for the attribute definitions.  Note the last three are off the elevation datum (section).
LFM.VDC
I understand the Level Block Concept for the regular Elevations, what I was getting at was having a elevation reported inside a ctext report. Now I have done it  but, it does not see the ":section" and the elelvation reported ends up being absolute.
Luciano
