EDIT SERVICE TEMPLATE/ ITEM FOLDER ICONS NEED TO BE LARGER
asherjoh
asherjoh
Is there a way to make the icons in the item folder larger? This is under edit service template.
THANK YOU
donald.kunath
Hello @asherjoh
Thank you for your post!
At this time there is no way to resize the icons in the edit service template, I do however see the value in this suggestion as it is very hard to see those very small icons.  The best work-around I have is to drag the item into your template, study what it is, keep it if you like, otherwise right-click and choose Delete Button.
I would like to suggest you post this to our ideas page for Fabrication and I am confident other users on that platform will agree.
Fabrication Ideas
If you found my post solved your problem, please click on "Accept Solution" to help others with similar questions.
Thank you and I look forward to your thoughts!
Donald Kunath
Technical Support Specialist
Installation and Licensing Forum | Revit Ideas board
donald.kunath
Hi @asherjoh
I hope you are doing well and making lots of progress on your project.
I wanted to check in and see if you had a chance to review my feedback from my last forum post, or if you have any additional questions for me?
If you found my previous post addressed your problem, please click on "Accept Solution" to help others with similar questions.
Donald Kunath
