Correction; not items you have built. Sorry
It is really a strange situation. All parameters will show in gray if the item is locked, but not disappear. And it looks like the item is not locked because the icons in the image you shared are not gray. So I guess the smaller edit item window makes the issue, because I notice the preview of the item disappears as well. Could you please try to restore the window?
Hope this could help you to solve your problem.
