DXF file for Cypcut laser system
I have a huge struggel with the DXF files from Camduct (opus)
example:
I draw string of text in OPUS, then i save what I have drawn. then I go in and nest it and then export the sheet as a DXF file.
 When I open the DXF file in the CYPCUT program, some of the lines are missing.
do anyone have this problem?
matthewweake
It looks like you are using the Stencil Font. It works fine for me.
Try these things:
  • Check the text looks correct in Opus.
  • Check the dxf output in another program such as DWG TrueView.
  • Use CAMduct to write the NC program and open that in CypCut. Use the default D5 Post Processor.
Matthew Weake
matthew.w@cadpro.co.nz
+64 9 302 4028
sboyerX23LB
Community Visitor
Community Visitor
go in cypcut -> file -> user setting -> -> user configuration -> optimize -> uncheck the "delete object smaller than"
