DWG TrueView & Object Enabler
Bangorsteel
Bangorsteel
Dear Sir / Madam
One of our clients needs to look at HVCA Ductwork and I advised them to download DWG TRueView & Object Enabler (I have given all the correct links to the client for their convenience).
They got back to me stating that the drawing does not open showing ductwork, so I installed the same said software on an test machine in the office and they are correct, ductwork does not show.
I have attached a screen capture of the error message that appears.
Can anyone help?
AARON @ BSF
Replies (7)
porterja
Hi Aaron,
Thank you for your question and for contributing to the Autodesk Community Forums!
I understand you are unable to see some HVAC ductwork utilizing and experiencing an error while opening a Fabrication dwg in Autodesk® DWG TrueView™. The probably cause for this is the Fabrication CADmep Object Enabler dbx file does not load properly in DWG TrueView™.
To resolve the issue perform the following steps in DWG TrueView:
  • Access the DWG TrueView options (NOTE: an open drawing is required to access the options)
    • Right-click in the command bar at the bottom of the screen > Options
    • OR
    • ​Click the DWG TrueView button in the upper left corner > Options
  • In the "Files" tab, expand "Support File Search Path"
  • Click "Add..."
  • Click "Browse..." and navigate to the DBX folder of the Object Enabler installation:
            C:\Program Files\Autodesk\Fabrication <version>\CADmep\DBX
            - Where <version> refers to the installed Object Enabler version
  • Click "OK" to add the path
  • Click "OK" in the Options dialog
  • Close and restart DWG TrueView
See Also
Autodesk Fabrication CADmep 2016 Object Enabler
Autodesk Fabrication CADmep 2015 Object Enabler
Fabrication CADmep objects do not display in DWG TrueView
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Jarrett Porter
Technical Support Specialist
porterja
Hi Aaron,
I hope all is well. Just wanted to follow up with you to see if the information I provided resolved the DWG TrueView issue. Please feel free to let me know if you need further assistance and I'll be glad to help.
I hope I have helped answer your questions and look forward to hearing from you soon.
Jarrett porter
Autodesk Technical Support Specialist
Jarrett Porter
Bangorsteel
Sorry for the late reply - that worked perfectly, thank you very much for your help!
Hi Jarrett,
I have the exact same issue as noted by Aaron but when I load the object enabler I still come up with the error.  I have loaded to the DBX folder which
contains the cadmep21_x64 file but I still come up with an error on restart. Would be grateful for any additional tips.  I have also attached a couple of screenshots of the error and loading of the object.
-Rich
Bangorsteel
I actually gave up on this, as no matter what I tried, nothing worked unfortunately :disappointed_face:
I did get it to work with TrueView 2015 and CADmep 2015 but no luck with the 2017 versions.
Bangorsteel
Totally agree.  Quite frustrating!
