Down Loading Refrigeration Piping from (building3dcontent.com.)
Can someone direct me to the manufacture/location of copper Refrigeration pipe and fittings I can use in a service. I'm looking for OD copper not ID..........
Thanks for your time,
Jim
davidronson
Dont they have a fairly complete Mueller catalogue? I believe Mueller has a refrigeration product line. You might look into that.
______________________________________________
Don't forget to "Accept As Solution" and "Give Kudos" when an acceptable solution has been given.
|| LinkedIn || LinkedIn Fabrication Group ||
David,
 I checked out the Mueller copper products and did'nt find the refrigerant piping sizes (ie. 7/8_1 1/8_1 3/8_1 5/8 ect.). The Mueller products that were in the services were for the plumbing water piping sizes. This may be an issue as the refer copper call out for 1/2" is 1/2"OD and the plumbing call out for 1/2" is 5/8"OD.  I dont know......I'm doing more research on this item today and I'll let you know where it lands.......
Thanks for the response,
Jim
In mine, I used the mueller catalog from service template "Mechanical - MuellerCopper_V1".  You can then add sizes that you need in the product list.  The project I am currently working on is requiring 1/2" Liquid and 3/4" Suction.  Hope that helps.
@Anonymous wrote:
David,
Jim
Easy fix is to copy a plumbing service then rename the data to the OD sizes.
Backnblack,
I went down that road.........The problem starts to arise with the quanity of small bore refrigerant piping vs plumbing, I cant make a complete sevice as it relates to the needs of the detailers. Refrigerant piping sizes 3/8"_1/2"_5/8"_3/4"_7/8"_1-1/8"_1-3/8"_1-5/8"_2-1/8"_2-5/8"_3-1/8"_3-5/8"_4-1/8"..........
I could possibly create a custom service per job if I knew the sizes prior to the start..........
Thanks for your response,
Jim
Product list all the sizes in the database and then set up services as required.
