Double Wall Duct
Double Wall Duct
When using a double wall spec it appears estmep wants to line the skin vs the outer duct. Is there a setting to change this so it will line the outer duct.
nathan.chapman
The setting you are looking for is within the itm itself.  Once you have double wall checked you will see settings to adjust skin inside vs outside and what material it should use.
Nathan Chapman
Production Manager at General Heating and Air Conditioning
Revit Architecture Certified Professional
Revit MEP Mechanical Certified Professional
Revit MEP Electrical Certified Professional
DynaFabrication Package Author
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDOS button.
That does not seem to matter...either way no matter what way you build the piece, it seems to want to line the inside piece.
Take a look at the square footage of the liner when you build a DW piece. If you build it as a inside or outside skin, the SF of liner stays the same and is based on the inner skin.
