Do Autodesk Fabrication CADmep 2017 Object Enablers work for Microstation
Could someone help me please.
If I install the CADmep 2017 Object Enablers would I be wright in saying that these enablers are only applicable to Autodesk products ?
The question is that I want to view the Autodesk Cadduct files in Microstation would these enablers help or am I wasting my time...
Regards Jamie
Object Enablers are ONLY applicable to AutoCAD and Navis based products.
They won't help w/Microstation.
There's an option in CADmep that allows the DWG to "save with graphics" that will embed the graphics in the DWG (they're typically regenerated by CADmep or the object enabler). This will allow other program that don't support the enablers like Microstation, AutoSprink, Tekla, etc to see the gbraphics when they open the DWG/DXF.
You'll likely want to copy the sourse DWG's to a temp folder before opening and saving them with this option turned on as it increases the size of the DWG file about 300%. Hence, keeping them isolated from the rest of your production drawings.
