Design Line - Hanger Fill places too many Hangers due to Fittings within the Run
Is there a way to have Design Line start the fill of hangers, based on horizontal changes in direction (Bends only) and ignore Tees, Thread-o-Lets, valves, etc. that are in the same run?
davidronson
Not that I'm aware of, it sees the branches as a change of direction so it is throwing in the Before/After. I would like to see this posted in the Ideas Station, if you post it there I will give it Kudos.
______________________________________________
Don't forget to "Accept As Solution" and "Give Kudos" when an acceptable solution has been given.
|| LinkedIn || LinkedIn Fabrication Group ||
Sounds Good. I'll post it there. We'll see if they do something with it.
Sincerely,
Eric Botts | Detailer
Pan-Pacific Mechanical
1205 Chrysler Drive, Menlo Park, CA 94025
P: (650) 561-8810 | F: (650) 561-8811 | C: (916) 796-8103
ericb@ppmechanical.com | Pan-Pacific Website| Please Contact Us
[cid:image003.jpg@01D2805B.3A3EF730]
This e-mail, including any attachments, is the property of Pan-Pacific Mechanical and is meant only for the intended recipient and may be a confidential communication. If you are not one of the named recipients or otherwise have reason to believe that you received this e-mail in error, any review, use, retention, dissemination, distribution, printing or copying of this e-mail is strictly prohibited. Please notify the sender immediately of the error by return e-mail and please delete this message from your system. Thank you in advance for your cooperation.
Dumb question. How do I place it in the "Ideas Station". Sorry, new to this forum.
I figured out how to do it. Thanks.
Just added to Ideas. Also, check this one out in the ideas section and let me know what you think.
"Lisp or Script for Stretching Hanger ATR to Global Z Elevation"
