Design Annotation Settings
- Mute
- Permalink
- Report
With the design line activated, I went to View (in the design line/takeoff panel) turned on annotate and went to settings to change some of the annotations that were displayed just to try and clean it up. I can switch between the annotations for Lines and the annotations for Nodes. Under Nodes it has the option for Elevation, but on vertical runs it gets pretty cluttered with two different elevation measurements stacked on top of each other so I wanted to turn off Elevation for Nodes, and turn it on for Lines, but there is no Elevation option under Lines. How do I add additional "Line Attributes", such as Elevation, for Lines?
Revit lives in the land of perfect and doesn't understand what construction is.
