Good Afternoon,
I'm in the process of teaching myself CAMDuct so that I can add connector types and parameters for their use in Revit Fab Parts. I've watched the Fundamentals Videos and have the MAP CAMDuct Training Manual, but haven't been able to find the information I need. I could really use a walkthrough or an actual manual, but I'm not able to find much, so I'm hoping you fine people can point me in the right direction.
I'd like to create 2 connectors [1" flange IN (1" Flange Out is the only current option) and TDF (not the default TDC)]. I'd also like to set parameters for when different connector types are used (i.e. < 12" duct width and height = S&D, > 12" duct width and height = TDF).
I'd also like to be able to create new pressure classifications (Low, Medium and High) and specify reinforcements based on SMACNA tables.
While I'm here, I suppose I should ask about creating Unistrut trapeze hangers as well.
I know that's probably asking a lot, so I truly appreciate any information you can provide.
