Creating an MAJ file for piping from Fabrication CADMEP
MOatman
MOatman
I am trying to make an MAJ file from Fabrication CADMEP to import into Revit 2016.  I am using the CREATECAM command on my piping drawing but none of the items are allowed to be output.  Am I doing something wrong or is there another way to create an MAJ file for piping?
Check the "status" of the pipe that you are trying to send to maj.  If it was done before, the status can change to "sent to fab".  It should be on design status or something similar.
gmurphy
Go to the Database then go to the Takeoff Tab then click Item Statuses under Services on the left.  The Checked boxes indicate what can be outputed.  Check the Output boxes that you want to allow to output.  My guess is you probably have Sent To Fab as the status on the items your trying to Create CAM on which is not allowed to output.
I do not have "sent to fab" as an option. Is there another setting that could be preventing the creation of the maj?
