creating a working part
How do you create a part in fabrication-mep that will allow you to assign a tag and also give it a name so it will populate into the bill as it should.
nathan.chapman
dmoore1071-
When you say make part do you mean you are trying to get your database set up with items?  If this is the case you will have to find the pattern that is close to what you are looking to use.  The command is Makepat to start the ITM creation.  Then from there you will create a tag to tag either a default parameter or a custom one.  I hope this gets you on the right track.  If not just clarify what your intention is and we will get you squared away.
Nate
Nathan Chapman
Production Manager at General Heating and Air Conditioning
Revit Architecture Certified Professional
Revit MEP Mechanical Certified Professional
Revit MEP Electrical Certified Professional
DynaFabrication Package Author
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDOS button.
fhaner.jose
i want create my own element. I don't want using MAKEPAT command.
Is possible?
fhaner.jose
