Convert to Fab parts in Revit, not working
mroble
Message 1 of 18
mroble
As I mentioned in a previous topic, I'm creating company specific services for our company.
I had one that I was able to draw generic piping in Revit, select the piping, click "Revit to Fabrication" or whatever, and all the elbows became fabrication elbows, complete with weld gaps and everything.
I took that service, duplicated it, and it seems to work fine, EXCEPT when I try to do the "Revit to Fabrication" option. It just barks at me. And it deletes my elbows.
I drew a 6" pipe, then turned right, then turned left, just made a jog in some 6" piping. When I used the previous Service as my "convert to", it worked great. I used the one that I created by duplicating it, it doesn't. I get two errors, and each error seems to point to the pipes on either side of each elbow.
My suspicion is maybe it doesn't know to select a long-radius or short radius elbow. Both are in that service. Both were in the other service too though.
Accepted solutions (3)
Replies (17)
Message 2 of 18
donald.kunath
Hello @mroble
Thank you for your post, and welcome back to the Forum community!
I would like to ask you some questions to help determine my troubleshooting direction.
What year version of Autodesk softwares are you using (2018, 2019)? Revit 2018 & Fabrication CADmep 2018?
Can you confirm that you are using the most updated version of Revit & Fabrication CADmep? Follow the articles below to determine if you are using the most up-to-date release for Revit & Fabrication CADmep.
Fabrication - Keep Your Software Current
Update Software in Autodesk Account
If your software is current, I would like to capture your workflow to help troubleshoot your issue, especially the "It just barks at me. And it deletes my elbows." message and details if possible.  Can you please do the following?
- A Screencast video (or a video from another screen recording utility) showing the steps you are going through.
 - A copy of the files used in the video (so that I can try reproducing the steps you are going through).
If you do not feel comfortable posting that information here, you are welcome to send the file to me in private.
Thank you for your help and I look forward to your thoughts.
Donald Kunath
Technical Support Specialist
Installation and Licensing Forum | Revit Ideas board
Message 3 of 18
mroble
I can confirm I'm using the latest version of Revit... 2018.3 I believe.
I need to check on the Fabrication though.
I'll get back to you really soon with more info on that.
Really quickly, my "workflow" I've been doing to try to make a Fab "library" that's company specific, was basically, duplicating existing Service Templates, and Services. And naming them something that's "my company name" prefixed. And at the same time, I've been populating a folder structure to be a "company centric" folder structure. So I can keep every ITM that's active in any company service and/or service template, it would be coming from our company folder structure.
Part of my reasoning is that this will allow me to download stuff, test it out first, then throw it into our "validated" folders, for company wide use.
The folders will be placed in a read-only area, and that's where everyone (except me) will be mapped to. Seeing as I'm the one that's going to evolve this library.
Like I said, I'll get back to you later regarding this, kind of neck deep in something right this minute, but I wanted to make sure you knew I saw this.
Thank you in advance!
Message 4 of 18
donald.kunath
Hi @mroble
Thank you for your feedback, I appreciate it greatly!
As far as you Revit version, I am not sure if you may have left it off on accident but there might be another update waiting for you.
2018-10-11 11_33_57-How to tie the Build number with the Revit update _ Revit Products _ Autodesk Kn.png
As far as your Fabrication Build, here is a link to help you determine whether you are on the latest version or not.
My experts and I did some initial testing and this is what we were able to come up with.
It is possible that the duplicated service lost some associate with your button mapping.  However this will not happen if you simply did a copy of the service, and changed nothing.  After reading through your initial forum post and your reply, it sounds like you are duplicating your service and possibly making changes.
Specifically you mention "I've been populating a folder structure to be a "company centric" folder structure".  If you add items or (populate) to a service, you need to add a button code, if you do not add a button code then you will have an empty placeholder as Revit doesn't know what elbow to pull and populate per the convert to Fab request.  By default when you add items to a service it does not have a button code.
Can you confirm that there are button codes for the items you are adding?
Another possibility is that the button mapping for bends have been un-selected, or unchecked, is this something you are seeing?
In Revit there might have been a change that is also causing this if all of your Fabrication CADmep content is set up correctly.  You can manually choose what buttons you would like Revit to populate with by selecting the button to left of settings in MEP Fabrication Parts window.
Here you can choose whether you want Revit to include or ignore the button depending on your preference.
This is a lot of information, hopefully this helps.
When possible please let me know if my suggestions helped to resolve your issue, if you found my post solved your problem, please click on "Accept Solution" to help other with similar questions.
Thank you and I look forward to your thoughts!
Donald Kunath
Message 5 of 18
mroble
I am pretty certain you are correct.
Yes, I'm duplicating, (with minimal modifications).
1. Copy all needed ITMs into my company file structure.
2. Duplicate Service, rename it to my company specific service
3. Duplicate Service Template
At this point all is gravy...
In order to make these service templates point to my relocated ITMs, I had to delete all the buttons and drop in new ones using the ITMs in my relocated area. I have not noticed a way to "repoint" an existing button to a different ITM. Seems like you need to delete, then replace.
And that's where your findings come into place. I'm not able to get back onto this until probably Monday, maybe Tuesday, but I'm going to dig into what you're saying. Plus verify I have the latest versions as well.
While I have you here, maybe you can solve another problem I'm having. But I'll post another topic on it, so this one thread won't split topics. And require two "answer acceptions".
Message 6 of 18
donald.kunath
Hello @mroble
I hope you are doing well and making lots of progress on your project.
I wanted to check in and see if you had a chance to review the suggestion(s) from my last forum post, or if you have any additional questions for me?
If you found my previous post addressed your problem, please click on "Accept Solution" to help others with similar questions.
Donald Kunath
Message 7 of 18
mroble
@donald.kunath, sorry for the delay, I had like 3 submittal dates all within 4 days of each other. I had to table my Fabrication development until after my last one went out yesterday.
Been chomping at the bit for 3 days dying to test this.
Thank you sir! That was it!
I noticed all those "Bend" options in the individual buttom properties were blank. I had to fill those in.
I am going to make a pass through all my Services making sure those are set.
Follow up question... I saw those needed set to "Bend" or "RedBend" or whatever. I did not see one for Tee... I did see a couple that looked like they were for reducing tees however. Is there a name that's not readily apparent for a tee that I should point them to?
Message 8 of 18
donald.kunath
Hi @mroble
No worries, there is always fires to put out and those come first!  Thanks for the update, I am glad we were able to get that going for you again.
As far as your follow up question, I would recommend if you couldn’t locate specifically Tee, enter this yourself as a value.  There are 3 different types of tee’s from the list but that doesn’t limit what you can enter as far as text.
I would recommend cross comparing your button mapping between your duplicated services so see how they line up, and if you are indeed missing anything small.
If you found my post solved your problem, please click on "Accept Solution" to help others with similar questions.
Donald Kunath
Message 9 of 18
mroble
@donald.kunath
I just found this nifty little location... 🙂
Message 10 of 18
mroble
@donald.kunath
Where does button mappings like this come from?
I mean, I can make things up. But I have to think there is a database somewhere that has all these stored.
I was looking through the old Service Template that came in by default.
Those flanges are like:
RFWN150
FFWN150
RFSO150
FFSO150
RFBF150
etc...
They all make sense, but I can't tell if these are coming from a database or not. What if I was to go in there and type 150RFWN? Seems like I can just type anything in there.
Message 11 of 18
donald.kunath
Hello @mroble
Thank you for your reply!
There isn’t a list of predefined button codes, what you are seeing as far as button mapping is by design.  In addition there is not a database that has all of these stored.
As you mentioned you can make the names up, or you can duplicate the names, but you will have to set the draw order and you would need to develop your own naming conventions.  If you use the same button code you will need set the lower and upper limits depending on your design.
If you found my post addressed your question, please click on "Accept Solution" to help others with similar questions.
Donald Kunath
Message 12 of 18
mroble
@donald.kunath
Thank you!
How do you set the drawing order?
I HAVE noticed that if you set the stuff in the bottom of your service template..
That sets a nice default setting for your upper and lowers
Plus, you can make a button do something different if you so choose too, so you're not married to the service setting.
I haven't seen anything about draw order though. At least not labeled as such.
Thank you for all your help so far!
Message 13 of 18
donald.kunath
Hello @mroble
Thank you for the screenshots and update!
You are almost there as far as draw order, in the button mapping tab or any window with Arrows you can select the item you would like to re-order, by selecting an up or down arrow - see below
I also included a youtube video that does a good job at explaining Service Setup in more depth.
If you found my post solved your question, please click on "Accept Solution" to help others with similar questions.
Donald Kunath
Message 14 of 18
mroble
@donald.kunath
Thank you! I'm going to dig into these again today. I finally got a clean slate on my desk for today, and I can dedicate an entire (or most of) a day to this.
Are you and your CADMEP professionals going to be at AU by any chance?
Message 15 of 18
mroble
@donald.kunath
Another quick question...
You stated "As you mentioned you can make the names up, or you can duplicate the names, but you will have to set the draw order and you would need to develop your own naming conventions."
When I do that, these do not become options in the button mapping, and therefore cannot set the draw order.
For instance, if I select a 150# raised face weldneck flange, I go in, type in RFWN150 in that field, then if I go to button mapping, there is no RFWN150 in there for me to move up, or down. Which is why I'm having such a hard time wrapping my mind around how you can just type anything in there. If it doesn't matter what you type in there, why type anything at all?
I guess I'm just used to specific text telling the entity what to do, you know? Think LISP. You mistype anything, the whole lisp fails. Old-school mindset, I know. haha
Message 16 of 18
mroble
@donald.kunath
Got my PVC Sch 80 and PVC Sch 40 to work, but I just took the default Charlotte templates and services and duplicated them. The only "change" I did, was add tabs. Pipes, Fittings, and Flanges and divied things up. So as to not have one tabs with 50 entities strung about in no specific order.
Also flanges come with Sch 80, but not Sch 40, so I copied the flanges tabs from 80 into 40 (thanks to the tip from the video you posted), and they work together just fine.
I guess what started my endeavor here was my next step would be to copy all the ITMs for the Charlotte stuff into my company specific folder structure, then re-add button scoming FROM the new folders, but, honestly, might not be worth it.
Message 17 of 18
donald.kunath
Hello @mroble
Did I understand you correctly, that your services are working now?
Thank you for the update!  Sadly I will not be attending AU this year, if you do make sure you take good notes!
I am pleased to hear you were able to get your templates to work by adding tabs.
If you have any further questions don't hesitate to ask in a new forum post.
Donald Kunath
Message 18 of 18
mroble
@donald.kunath
Yes, it's working now.
Previously something got wacky when I tried copying the ITMs over to the new folder structure, then deleted and replaced the buttons with the relocated ITMs.
For now, I'm just going to use this as it is, and as I putz around in the settings, I'll begin to fine tune these again. But for right this minute, it's working like a charm.
I'll be attending, I can't wait. I didn't see any classes centered around CADMEP though, not a deal-breaker obviously, but do you happen to know where I can obtain some good literature on management of CADMEP?
It almost seems like it's Autodesk's hidden little secret that it likes to keep hidden in the shadows.
