Content Need
Content Need
Hi all,
I need to be able to access the old MEP Metric Content V2.1 in order to edit the busbar and I can't locate where the *.IOX database is (not even with a search on my machine.
Reason being is that the old busbar can be used in Revit, where as the new V7.05 powerbar as it's now called is not yet supported when I load it in.
Any pointers on to where this database is located would be much appreciated.
The MEP Metric 2.1 content is the Metric Fabircation content that ships with Revit 2018.
You can find it in the following folders of the install media...
32-bit media...
.\Revit\x86\MEP_Fab_M.msi
64-bit media...
.\Revit\x64\MEP_Fab_M.msi
If you installed Revit, the content should be located here unless you removed it....
C:\Users\Public\Documents\Autodesk\Fabrication 2018\Revit MEP Metric Content\V2.1
Or you can download it from Autodesk here....
https://knowledge.autodesk.com/support/revit-products/getting-started/caas/CloudHelp/cloudhelp/2018/...
