Connector error
rraghavendraTT3JQ
Connector error
rraghavendraTT3JQ
I have a default connector for the pipe in cadmep 2021 which is unlocked. When i load it into the revit model the connector is showing as none. I previously had same settings and the connectors were working fine now it is showing as none when i load them into the revit model. I already have a bunch of such services in my actual revit model. I have to update the database now and I am afraid that I might loose all the existing connections. How should I go ahead?
Mike_Arcari
Make a copy of the model and then try it.
if it wipes them out then you have the original to go back to and try something else
