Close Design Line Command?
Anyone aware of a keyboard command that will artificially close the active design line?
Or a keyboard command capable of switching the active design line to a different one by selection?
I want to automate (lisp) doing a 3D erase/3D fill on every individual design line in a model and I can't figure out how I could potentially do that without somehow closing the active design line dialog.
porterja
Hi tfs-us,
Thank you for posing this very good question. At this time, there are no keyboard shortcuts/commands like the ones you have requested available. This is due to the fact that there can be only 1 design line active at any given time as there are often different services with different lines.
This would be a perfect request to enter into the Fabrication Ideastation. Also, we are always looking to improve our products and the following link is set up for you to submit feature requests directly to our Development group: PRODUCT FEEDBACK. I encourage you to share any ideas as our Development group is always interested to hear your feedback directly since you are better suited to state the business case for a feature request.
Please feel free to let me know if you need anything else and we will be more than happy to help. Take care!
Jarrett Porter
Technical Support Specialist
In a way, the command i seek already exists, but it has issues.
Example:
(defun C:TT ()
  (command "NEWDOBJ" "TRACEDESIGNLINES")
I use this to partially close (more like deactivate) whatever my active design line currently is and trace a polyline thus making a new design line from a 3Dpolyline.
However, I have absolutely no idea why this works. The only thing I can think of is NewDobj starts doing what it is supposed to do, but gives focus back to lisp sooner than it should thus enabling it to start the TraceDesignLines (or any other single command IE Move), but if the lisp trys to execute anything beyond that point eventually the NewDobj command will take focus again and it cannot be closed without user input. If I stop input from lisp after issuing another command the NewDobj command is somehow canceled and all focus will in the new command I seemingly slipped past NewDobj. Example of NewDobj forcing its way back in:
;any command can take context and cancel the NewDobj if lisp ends
(defun C:TT2 ()
  (command "NEWDOBJ" ".move")
  (princ)
;but if lisp trys to keep running NewDobj will eventually take back over.
(defun C:TT3 ()
  (command "NEWDOBJ" "move" (entlast) "" nil)
  (princ)
The bottom line: I think the NewDobj command is subdivided into issueing multiple commands within itself and that allows lisp to artificially sneak back in where it shouldn't be able to. The next part of the problem is that the NewDobj command cannot be closed through traditional means of issuing "" or nil.
This is all very confusing I know, but I really believe this is a design flaw that minimal changes could provide large gains to the community with regards to design line automation tasks.
