Clearance around Fire dampers
Avinash.HulimavuQS2DX
Hi All,
We have been using revit and recently made the transition to fabparts in revit. was wondering if there was an option to show clearance zone around fire dampers (duct accessories)
Can we do something similar in fab parts ? if so can you please guide me in the right direction
Thanks in advance
craigjonnson
No you cannot add a clearance to fabrication parts. I use a hybrid of Revit rfa for all Equipment and inline Equipment. ITM's for all duct and pipe services.
nathan.chapman
If your using fabrication within CAD then a wrapped object would allow this.  Just be aware than you would need to build a CAD object for each size.  Not the best way but would do what you want.  If you're in Revit these will not be supported and the best method is what craig mentioned.  This is also how we manage it.
Nathan Chapman
Production Manager at General Heating and Air Conditioning
Revit Architecture Certified Professional
Revit MEP Mechanical Certified Professional
Revit MEP Electrical Certified Professional
DynaFabrication Package Author
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDOS button.
