Changing the default setting for a branch take off in the design line
Kenny_Maciver
Kenny_Maciver
Just finding my way around Fabrication CAD MEP. When using the design line the default circular fitting for a branch take off is a curved boot (TBS). I would like the default setting to be a Pressed Tee (TCP). Is there a way in the set up to achieve this?
Many thanks in advance
nathan.chapman
Go to the service you are using to fill the design line and add/change the button mapping for Bend to point to the code you have on the TCP button.
Nathan Chapman
Production Manager at General Heating and Air Conditioning
Revit Architecture Certified Professional
Revit MEP Mechanical Certified Professional
Revit MEP Electrical Certified Professional
DynaFabrication Package Author
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDOS button.
Kenny_Maciver
Very helpful. Many thanks
