Change Pipework End Type with a script
MOatman
MOatman
Is it possible to change the Pipework End Type of objects using a script.  I want to change it from "Not Set" to any other setting.
See attached for more info.
davidronson
I don't believe scripting has that functionality. Looking at the .chm file, I only see connector options at the Item level, none give me access to the development of the connector in the database.
______________________________________________
Don't forget to "Accept As Solution" and "Give Kudos" when an acceptable solution has been given.
|| LinkedIn || LinkedIn Fabrication Group ||
nathan.chapman
David hit it on the head in that scripting only gets the the item level not database.  I looked at the API and dont see a way to do it with that either.  Maybe in time it will come.
Nate
Nathan Chapman
Production Manager at General Heating and Air Conditioning
Revit Architecture Certified Professional
Revit MEP Mechanical Certified Professional
Revit MEP Electrical Certified Professional
DynaFabrication Package Author
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDOS button.
