Change default fit to sheet size
kunovac.enis
kunovac.enis
Hi!
Where do you change the "Fit to sheet size" default? It´s now set to 2500x1250 but we want to change it to 3000x1500.
matthewweake
Check out the different sheet sizes you have for each material. Make sure the default sheet you want to nest on has a tick.
Matthew Weake
matthew.w@cadpro.co.nz
+64 9 302 4028
