CAPmep - whats included?
stevenhcox001
stevenhcox001
Does CADmep include CAMduct & ESTmep?
I want to be able to layout duct systems, then create the cnc with CAMduct.  Based on videos I have seen this is the way to go if they are all in the same package.
Thanks, Steven
matthewweake
Hi Steven
They are 3 different products using the same database. You can do item-by-item take-offs in CAMduct which is OK for small jobs. You can use ESTmep and CADmep for doing runs of items fully populated using Design Lines.
Matthew Weake
matthew.w@cadpro.co.nz
+64 9 302 4028
stevenhcox001
@matthewweake,
Thanks for the reply.  We use CAMduct every day for all of our duct manufacturing.  However, because we do many larger jobs, it looks like CADmep might be a better solution.
I need to study up on this some more.
Thanks, Steven
matthewweake
I would suggest you consider ESTmep or go down the Revit with Fabrication content path. I try to avoid CADmep on sites that haven't used it before.
Matthew Weake
+64 9 302 4028
mgalicki7M78A
How do you remove specs that are not needed? Thank you
