Camduct2020 rotation nesting parts problems
Hi everyone,
I have this problem with Camduct2020:
If I want to manually rotate a nesting part, I can do it only by 180°.
This happens only with the items that I pick out of the catalogue items.
I can rotate with the desired angle only the nesting parts  that come from an item created in OPUS.
Hint:
@ links to members
jesseKH32J
Tool options at the top under operation. Change value to the specific degree of rotation you're looking for.
LanceTSM
Check "Database - Fittings - Pattern Switches - Developments - Graining"
If it is Ticked, that will restrict your rotation to 180 deg.
A bit late replying but hadn't seen this 'till it was recently bumped.
