CAMduct post processor
sfrasher
sfrasher
Is there a post processor that will work with Torchmate Accumove 2,  it is a .gm extension.
dyoung
No. Although depending on the code, one of the others may work. D6 is always worth a try. Looking at the NC code required can help inform.
You can create a custom post yourself in the software (not easy if you're not familiar w/NC or G-Code) but sometimers even that doesn't give you enough felxibility in which case you can have a custom VPL created.
If you need a custom post, contact Applied Software (in the US)....
https://www.asti.com/
Or A2K (if Australia)
https://www.a2ktechnologies.com.au/
Darren J. Young
http://www.darrenjyoung.com/
https://www.linkedin.com/in/darrenjyoung/
