CAMduct Part Label Graphical Pattern View
kmilesZXEY4
kmilesZXEY4
I have two issues with the graphical pattern view for the part labels. First, I have the view set as an isometric view. The annotations never seem to be very clear no matter what I set the dimension offset and margin to in the takeoff style tab in the properties. Is there a way to get these annotations to come in clearer? My second issue is that the said annotations come in as "A, B, C..." Is there a way to have them display the actual dimension? My shop guys to not want to have to reference over to the item dimension list to get the actual dimensions.
Mike_Arcari
you can change these settings by doing the following -
go to file menu and select print layout/labels
select part labels at the top left
right click on the graphical pattern view box and select properties
select properties again on take-off settings tab
select take-off style
from here you can change the text size and also other options relating to how it appears on the label
s_i2
Hi Guys,
It's been for a while ago but, just wanna know, how did you fix this issue? I am having same problem. I can't get the actual dimensions.
