Camduct layers on DXF export
dimitry.shan
dimitry.shan
Hello all,
     I am working with duct board and need to cut some sides with straight knife and others with angled knife. However, my machine needs the DXF file to have layers; one layer corresponds to one tool (straight knife) and the other layer to angled knife. i was able to nest a part and camduct shows the green and blue (straight and angle cut) lines correctly but this does not show on the DXF file. Am i missing a setting?
Replies (23)
dimitry.shan
Dear Mr Lance,
    Please find the attached dxf file i am getting, see the layer 0 looks like a bevel but it is not even defined nor is it correct, but i am getting KNIFE as correct layer. Please could you share your database with the settings? that would save me really...
dimitry.shan
After much struggle i came back to your solution, which works as i need it to... what i do not understand is that why can this not be done via the nested page?
LanceTSM
It can be done from exporting the nest, as I showed in my last post.
You just need to get your settings correct.
dimitry.shan
see this is my problem i have tried every thing but it just would not output in layers... if you could only share your database with these settings it would solve this problem...
