I have made a script to export DXF with the command item.writeDXF because I need the DXF's for importing automatically into Trutops software for a Trumpf laser.
I have noticed that the desired layout is not exported via script. Via "Database - Manufacturing - Tool Defaults - Layer Mapping - Export" the settings are done, and if I export DXF within Camduct (via right-mouse-button and "export DXF" then all is fine with the DXF files.
But if I do the same with command item.writeDXF, then Camduct does not take into account the export settings from the "Database - Manufacturing - Tool Defaults - Layer Mapping - Export"
Anybody have the same issue in the past and found a workaround ?
