camduct 2021
camduct 2021
i have installed a new trial version of camduct 2021 to see if i can use it.
apart from all the other issues ive had to get this far i am finally at my wits end.
if i use the default material size sheet it nests ok
if i copy the default material size and then edit them to the alternate size sheet i use all goes to hell.
the nests 'look' like they are nested in the bottom left corner of the sheet ok but........
when i load them into my dynatorch table the cutting is started about 600mm in x and 200 mm in y ... then the nested job.
It basically adds a x and y value to move everything right and up before it starts the cut...
How the hell can i stop that...
even using the default material sheet size and resizing the sheet doesn't help...
regards,
Bill
Replies (0)
