CAMduct 2017 Crashing when using the nest option
When selecting the nest option in CAMduct 2017 when a job is selected the software crashes, Everything else works until we click the nest option
dyoung
Every job regardless of what's set to be nested?
Try a new job with a single piece of duct. Occasionally, you'll get an odd piece that can cause issues.
At what point does it crash?
Go to the folder the config points to (where MAP.INI is located) and delete the *.PRN files which for the printer configs. You'll then need to reset your printers but I've has corrupt PRN files cause crashes before, typically when it's processing prior to displaying the preview of reports.
The other thing you can try is changing the nesting algorithm.
Darren J. Young
Director of Operations Technology
Hermanson Company LLP
1221 2nd Avenue North
Kent, Washington 98032
http://www.hermanson.com
Every job regardless of what's set to be nested? Every job
Try a new job with a single piece of duct. Occasionally, you'll get an odd piece that can cause issues. Tried brand new pieces and old
At what point does it crash? as soon as I click nest
