CADMEP 2018 Adding damper automatically with tap does not work.
Switching to CADMEP 2018 form 2016 when you place a tap that you have the button stacked with a damper and under the button properties have it running a script to add the damper automatically it does not.  It does pop up the damper like it used to but you but clicking the okay makes you place it manually and it puts it in the duct sideways in line with the duct the wrong way.  Has anyone found a fix for this yet?
The script I am using is:
Takeoff
Increment To Next Valid Item
Takeoff
Remove Attacher
Takeoff
johnwbrown573
Try
Takeoff
Force Fix Relative
I add "Remove Attacher" after the damper is placed.
