Blocks not exporting as IFC
The blocks highlighted in image are not exporting as IFC .
If you select the blocks and convertto3dmodel then they will IFC out.  IFC export only works on CADMEP items. So normal Autocad 3d blocks will have to be convertedto3dmodel.  Hope this helps.
Thanks it worked
