Batch Spool
Batch Spool
When batch spooling all the BOM from previous drawings in the batch show up on the spool drawing. Is there a way to avoid this with out reverting to single spooling?
nathan.chapman
It seems you don't have your spooling set up correctly.  Follow this link https://knowledge.autodesk.com/support/fabrication-products/learn-explore/caas/CloudHelp/cloudhelp/2...
Nathan Chapman
Production Manager at General Heating and Air Conditioning
Revit Architecture Certified Professional
Revit MEP Mechanical Certified Professional
Revit MEP Electrical Certified Professional
DynaFabrication Package Author
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDOS button.
my define spools does not have a process section to choose layout tabs. fab mep 2015 might not have it.
I needed to rename my spool template sheet spool_template. This made it so that it will always return to that sheet before it creates a new spool.
