Autosave
Autosave
Autosave
I'm having an issue with my Autodesk Cad environment. I'm using Fabrication AutoCAD 2017. I have my Autosave set to every 30 minutes but it seems to keep launching after 4 to 5 commands. It's intermittent but very annoying because it freezes up my computer for up to 2 minutes until it's done. I tried unselecting the Autosave option in my "Options/Open and Save" dialogue box but it still keeps happening. Is there a setting with some type of numeric variance within the "Options" environment that can help to eliminate this from happening on such a constant basis? Proxy Graphics settings, or possibly a command that will help fix this issue? I also made sure I unchecked the Automatic Backup box in the Fabrication Database (see attachments).
bjwardlow
Have you changed your Autosave at key points? I think it is set to 10 out of the box. Make the number higher, or set it to zero if you don't want it to save at key points.
bjwardlow
Nevermind, it appears you already did that. I am not sure then, changing that number to zero has worked fine for me.
Yes. My Autosave at Key Points is set to 0. Thanks.
Could still use help from anyone with any insite on this. This is still an issue on a daily basis.
