Auto oversized parts
johnrZPEKX
johnrZPEKX
When we nest parts from maj orders created in Revit, the parts that need to be sliced (due to being larger than the sheet size) will automatically be sliced with no prompt from CamDuct software.  Is there a way to get the software to give us some sort or prompt that tells us that a part is oversized like it does when we are in a part then "Accept" it?
Mike_Arcari
Hi John
if you select all the items first prior to nesting and right click to bring up sub menu and select oversize check as per screenshot below. this will list all parts that are too big to fit on default sheet size and you can edit from there.
to switch off the auto oversize option go to database settings-manufacturing-oversize options
from there you can change the auto settings.
