Auto Login settings
SusanMcCurdy
Auto Login settings
SusanMcCurdy
I am trying to set up Fabrication CADMep for Auto Login when the program is opened.  However, the option for this is greyed out.  The main reason I want to set it to Auto Login is that when I print anything, after a long wait, the login window reappears and I need to re-login in order for the drawing to print.  This seems to only happen on my machine so it must be a local setting?
AutoLogin is enabled on a case by case basis for the Fabrication User accounts. Go to the "Configure Users" program and edit the user account you want to have this enabled for and add it there.
I suspect (not tried) this option in Edit Configuration is really there not to "Enable" but rather "disable" the AutoLogin in the event someone with permissions to Autologin selected that option when logging in and needs to clear it later.
