Alignment notch/marker
GabeGarcia
GabeGarcia
does anyone know how to put a notch or marker on seam. say i'm creating a small pipe section or damper section, the seam will be spot welded with a 1/2" lap. i would like to have the notch on the male edges so i can align the seam lap when spot welding. any help or ideas will be appreciated.
dyoung
You can configure custom notches in CAMduct. Have you explored the notching section of the database? It's only accessible from CAM.
Darren J. Young
Director of Operations Technology
Hermanson Company LLP
1221 2nd Avenue North
Kent, Washington 98032
http://www.hermanson.com
GabeGarcia
Darren
i have looked into the database in camduct under Fittings<Connectors<Notches and also Fittings<Pattern Options<Notches. im still not getting the results that im looking for
thanks for the input
